Taps have very low pressure-advice please
Discussion in 'Plumbing and Central Heating' started by Homervanderjazz, 12 Feb 2012.
  1. Homervanderjazz
    7 Feb 2012
    95
    Thanks Received:
    3
    Country:
    Hi folks, I have recently had a new bathroom fitted, a result of this has been that the taps in the sink have very low water pressure in them, the bath ones seem fine however. When I questioned why this was I was told it was to do with the pipe attachments of the sink and that they were too small. I find this hard to believe. Any thoughts on what this could be? Thanks
  2. denso13
    22 Jan 2007
    2,369
    Thanks Received:
    439
    Country:
    Do you have a low or high pressure system (combi or tank fed)? Are they the correct taps for what you have?
  3. landyandy
    2 Nov 2008
    675
    Thanks Received:
    68
    Cheshire
    Country:
    Are there any service valves fitted under the basin.
    If so are they turned on enough?
    Andy.
  4. Homervanderjazz
    7 Feb 2012
    95
    Thanks Received:
    3
    Country:
    There are two valves underneath the sink, both are fully open. I have a tank fed system, any thoughts?
  5. seco services
    3 Dec 2007
    15,656
    Thanks Received:
    1,248
    Essex
    Country:
    sounds like the flexi hoses :idea:
  6. danny1985
    10 Feb 2012
    19
    Thanks Received:
    Manchester
    Country:
    If your connections reduce down to a smaller pipe bore at the sink taps. This will reduce the pressure.. Any service valves should be 15mm full bore on gravity systems.
  7. TicklyT
    30 Jul 2006
    3,480
    Thanks Received:
    337
    Hampshire
    Country:
    Er.. Not quite - Small bore pipework or flexis will reduce the flow rate for a given static pressure.
    With a tank fed gravity system, the water pressure available can be less than 0.2 Bar. Many taps on the market are only suitable for high pressure (1 Bar or more) systems. Check the manufacturers' blurb on the boxes or fitting instructions for the minimum working pressures of your chosen brassware.
  8. danny1985
    10 Feb 2012
    19
    Thanks Received:
    Manchester
    Country:
    sorry I meant flow rate rather than static pressure..
  9. HERTSDRAINAGE2010
    9 Apr 2010
    6,459
    Thanks Received:
    905
    Hertfordshire
    Country:
    My guess is wrong taps fitted.
    Andy
  10. JohnD
    15 Nov 2005
    43,881
    Thanks Received:
    1,956
    Perth
    Country:
    I'm with Andy. You have tank-fed bathroom, so low water pressure, and you have recently fitted new taps. I bet the taps are really stylish Italian ones. If you look at the advert or the instructions for the taps it will probably say they are for high-pressure supplies.
Loading...
Share This Page
