Hi guys,
I'm new to this forum.
I have changed my basin separate tap to a mixer tap. There was a low pressure on hot water side and thus, after deciding on different things, I decided to put in line a pump to boost the pressure. Yes, it worked but not every working is pleasant enough.
Now, I have high pressure hot water but as soon as I open the cold water valve/tap to have a warm mix, the pump stops working. So, again, I either have very hot water only or very cold water only. It seems the problem was spinning around that £100 spent on the work.
Does anyone know how I can stop the pump from stalling when cold water is on?
Thanks in advance.
Thanks in advance.
