I am far from being an expert on such matters but i know something isn't right with my CH system and I can't face another winter wrapped up in 14 layers of clothes!
I have had my Baxi Solo 2 boiler serviced ever year since I had it installed approx 8 yrs ago, including last year when my problems started.
The boiler fires up for the 1st time in it's programme but shuts down again before either the HW or Rads get any where near the temp they should be. It also refuses to fire again during the 'on' period of the programme, although it can encourage it to have another go if I turn it off at the mains & reset the boiler. From this I am (hopefully!) correctly assuming that my pump is working?!
I live in a flat so all the Rads are on the same level. I have replaced the room thermostat & the control panel so don't think there is anything wrong with those. The thermostat on the cylinder is currently set to 70 degrees, although this seems to make no difference to the water temp. And bearing in mind that i am not an expert, am i supposed to feel some resistance if i moved the lever on what i think is the 3 port valve?
Although i know i am out of my depth I am reluctant to call in the company that service it considering they didn't seem to fix the problem last year! So all I ask is that someone give me a rough idea of things that could be wrong with it, so when I have to call the gas man in I look like i have some idea of what I'm talking about... so please, I am appealling to all you good and honest fitters out there to give me a clue!
Thanks!
Helen, cold but hopeful!
Thanks!
