Hi there i have a Sabre 25HE boiler. I have noticed the led has been flashing every 0.5secs (as opposed to the usual once every 6 secs) when the boiler is not calling for heating nor hot water during the rest periods in between.
(it only goes to the normal 6 seconds flash when the the boiler is in 'off' mode)
The instructions indicate this is a temporary fault (eg APS fault or low water pressure).
The water is also rather lukewarm.
Should i try ajusting the DHW flow switch to see if this helps or call for assistance. The instructions booklet recommends the action required for this fault simply as 'wait' .........?
