no bcos it doesnt workAdam_151 said:this any help? http://www.-no ads-.co.uk/armoured1.htm
james 29 said:Crafty, dont follow the snips thing,
Best way is to use a hole cutter and fix the gland as shown. Some swa have an olive inside and others have a roughened section on the actual gland. Make sure the narrow chamfered end points into the gland first i it has one. (wont tighten up otherwise)
Work out roughly the amount you need to strip and score round with a junior hacksaw. By score i mean cut the a few mm into the armouring without going too far. Cut down to that point with a stanley and then strip the outer sheath. The armouring should now just fold back and snap off.
In my oppinion it disturbs the armouring too much touse snips like that and it can be a struggle to get the back gland on.
cheers ban. thats what i was looking for. My gland has another part, with a rubber compression ring in it, i take it this is for use outdoors and is just meant to grip the plastic, not the armour.ban-all-sheds said:Diagrams for (one type of) gland, and a link to the topic to which I think you were referring..
//www.diynot.com/forums/viewtopic.php?p=219838#219838
crafty1289 said:My gland has another part, with a rubber compression ring in it, i take it this is for use outdoors and is just meant to grip the plastic, not the armour.
