I can not figure out how to connect Odyssey 5 bell to Texe 832 control panel.
Odyssey has following connections:
A(12V) - permanent positive supply
B(Bell) - negative applied output to activate siren
C(Tamp) - negative removed on tamper input
D (0V) - permanent negative supply
S(STRB) - negative applied output to activate strobe
Probably
A(12V) goes to Aux12 +
D (0V) goes to Aux 12 - ?
Then:
B(Bell) goes to Panel output 1 (Siren)? I have 2-wire smoke detectors connected to PO1. Should I use another Panel Output?
S(STRB) goes to Panel output 2 (Strb)? This is free.
Where should the C (Tamper) go?
To Aux input? (this is free at the moment)
or to a zone?
I only have 5 wires going to the unit.
Thanks in advance,
Eric
Probably
Then:
or to a zone?
Thanks in advance,
Eric
