Texecom Premier 48 panel outputs software config
8 Jul 2010
Any advice appricated regarding programing the panel outputs of the Premier 48
I have managed to program the panel to sound the klaxon on panel output one as bellsab this mimics the bell sab timer and works fine
I do need help
panel output 2
what I am trying to acheive
zone 7 has a four wire smoke (Exodus)
I wish that the smoke sends an alarm signal to the pizeo sounder on output 2
I have the com2400 on board
when I configure the output as FireSounder the smoke detect when triggered fires the external intruder alarm box as well as the pizeo
it also sends a text message
I only want output 2 to sound the pizeopsee below for various configs
none of which have managed to send both a text message and sound the pizeo at the same time
the config works fine if its just configured to firesounder but, this operates the external bell box (intruder Alarm)
is there a work around for this so that I can acheive the above
zone 7 fire-----> panel output 2 fire sounder
which sends txt message but fires external intruder alarm instead of wired pizeo on output 2
zone 7 fire-----> panel output 2 mimic zone 7
zone 7 Latchkey (monitor) -----> panel output 2 mimic zone 7
zone 7 not used ------> panel output 2 fire alarm (areas) D
smoke is in area D which is store room
to recap, zone 7 is a four wire smoke which is in area (D)
the panel output 2 has a pizeo attached to it
when set to firesounder this sends a text message, but also triggers external sounder (intruder Alarm bell)
zone 7---->panel output 2---Pizeo ---sends sms text
much appriciated Tony
