so these two types of trvs can b fitted where you can not identify which pipe is the flow or return? ie no rads on the wall just 2 pipes from floor in each room so can not turn heating on to identify flow. thaxcorgiman said:the best laid plans of mice and men
J1 said:so these two types of trvs can b fitted where you can not identify which pipe is the flow or return? ie no rads on the wall just 2 pipes from floor in each room so can not turn heating on to identify flow. thaxcorgiman said:the best laid plans of mice and men
so nick i could basically take a chance on each rad with just your normal trv?nickso said:J1 said:so these two types of trvs can b fitted where you can not identify which pipe is the flow or return? ie no rads on the wall just 2 pipes from floor in each room so can not turn heating on to identify flow. thaxcorgiman said:the best laid plans of mice and men
in general yes....but the worst that happens is you need to turn it round if its wrong. doesnt always cause a problem with one direction valves anyway if they were on the wrong way.
so what in your great experience would you recommend in this situation?nickso said:if you have some lying around and you are a gambling man then take a chance.
you will know if its wrong cos they start chattering when the valve is only slightly open.
nick you are a diamondnickso said:well lets keep it simple then and buy bi-directional valves. you wont go much wrong then.
]J1 said:nick you are a diamondnickso said:well lets keep it simple then and buy bi-directional valves. you wont go much wrong then.
how can i do this corgiman theirs no rads on wall just 2 pipe s sticking out of floor in each room can i turn heating on and will flow pipe get hot even without no rads on wall? (all pipes are capped)corgiman said:]J1 said:nick you are a diamondnickso said:well lets keep it simple then and buy bi-directional valves. you wont go much wrong then.
dont trust em
before you install them ensure that you know which end of the rad is the flow (really easy its the pipe that gets hot first) and install the TRV there
even the bi flows can rattle and hum on the return
