Thermostatic Mixer Valves
ijc
17 May 2005
Sheffield
Hi
I'm about to replace a bath-tap-mixer style shower with a cubicle and proper thermostatic mixer. It will be fed via combi boiler and rising main, and currently this provides adequate pressure (nothing spectacular).
My question is this: is it worth buying a thermostatic mixer valve with a higher pressure rating (as claimed by B&Q!), in order to ensure no loss of pressure? The difference in prices between the lower and higher rated models is remarkable, but I'm very happy to pay for something that will ensure no drop in pressure compared to the existing bath-tap mixer!
Grateful for any advice and or related tips.
Thanks in advance
Ian
Must be thermostatic if you have a combi .... Its to do with the risk of getting scalded
Great answer; now what was the question !
Don't have direct experience of this but is that B&Q the company or some bathroom section store 'assistant'. My understanding is that the 'high pressure system' valve have 1/2" (just about 15mm) connectors and the 'none high pressure system' i.e. gravity fed valves have 3/4" (almost 22mm) connectors, ala bath taps vs basin taps.
So I guess if the feeds to the mixer are by 15mm pipes would there be any gain on having a larger than 15mm connectors ? Probably not unless the inner bore of the valve on the 3/4" is larger than the inner bore of the 1/2" than you could make a case for 2 15mm feeds (hot and cold) coming together in the valve would produce a greater output through a larger bore mixer than through a smaller bore !
You can buy what you like, if you are running a shower from a combi, the flow rates are notoriously ****e. Unless you are willing to shell out a few shillings.... :LOL:
sorry to diasgree......in my opinion combi showers are the one of the best ones....as long as its powerfull enough...ohh and no-one else uses the water at the same time
traineegasman said:
, if you are running a shower from a combi, the flow rates are notoriously s***te.
Not so Tgm.
My shower off the combi is superb, not measured the lpm but very happy with it. :D
Friends then?? :cry: :cry: :cry: :D
Ok.
1) Press reply to post
2) Click img (2nd button from top left)
3) Go HERE
4) Left click under smiley chosen in the bar
5) Bar changes colour then right click
6) Select copy
7) Back to reply box, right click and paste.
8) click img button again.
HEY PRESTO
Above courtesy of Kevplumb :D
Expect a flurry of smilies now from everyone :LOL:
