Assuming their is two fuse spurs attached to dual back box and both are feed from separate circuits each of which are both feed by RCBOs, would this constitute poor design as both circuits would be earthing the same back box?
Supplementary bonding in a bathroom requires the earth of every circuit to be joined together.
Was he fitting kitchens and bathrooms before becoming an electrician?
Supplemetary bonding was required under the 16th edition and still required depending on circumstances under the 17th edition.
Under the 17th edition regulations (BS7671:2008) supplementary bonding in a bathroom may be omitted where certain criteria are met. These criteria are as follows:
All circuits comply with the requirements for disconnection times
All circuits are RCD protected by a 30mA device maximum
All extraneous conductive parts in the location are effectively connected to the protective equipotential bonding.
