bloody cowboy electricians these days..
switch 1, you have live in, live out, and strappers to the next light..
switch 2 you have strappers in, and strappers out .. this is an intermediate switch..
switch 3, you have strappers in and switched live to the light..
there should be 3 neutrals in a connector block on switch 1, with the 2 lives from the T+E's into the COM terminal of the switch..
then 2 strapper wires from the 3core+E into L1 and L2..
the neutral should be carried by the blue cable or black cable in the 3core depending on the cable colours..
at switch 2 you will have 2 neutrals ( blue or black from above ) into a connector block, then 2 strappers from one switch into the L1 IN and L2 IN terminals, and 2 strappers to the next switch into the L1 OUT and L2 OUT terminals ( or whatever they are marked... usually 2 strappers in the top, and 2 out of the bottom of the switch.. )
at switch 3 you will have 2 neutrals into a terminal block ( 1 from the intermediate switch in the 3Core+E, and 1 to the light in the T+E ).
2 strappers from the intermediate switch into L1 and L2 of the switch ( same colours as the outgoing ones from switch 1. ) and 1 switched live to the light ( the Live colour from the T+E to the light.. )
