Montolit Masterpiuma.
You'll need a big one to do 600mm+ diagonals.
Ideally you should be using a wet saw though.
Have you thought of hiring one fora few days?
Tile blade on grinder.
Just my first search, bought this up. Grinder and Cutter Hire | Power Tool Hire | Travis Perkins Most tool hire will negotiate.Deffo for L shaped ones.
I have, the ones perfect for the job start at £83 so best to buy own which I could use to tile the bathroom next.
That's a good idea.. its just the dust that goes everywhere.. I know the DIY tile cutters also space water everywhere..
basic wet cutter - doesn't need to be expensive. Keep it wet for long blade life. Do it outside with plastic/cardboard to contain overspray. The smaller cutters can be as good as the bigger ones as the wheels are thinner and remove less material.
I honestly do not believe that you can get the same kind of finish from a £50 plasplug wet cutter.
I can take a 10mm border out of 3 sides of a 110mm sq tile and keep it in one piece (e.g. for slotting under a socket) by cutting multiple slots and snapping out the shards in between.
