Hi guys. I am doing up my bathroom and got rid of old tiles and wall paper. In doing so, not only the finishing plaster was not sound and therefore i had to remove nearly most of it but also i realized that a section of bonding plaster is not properly bond to the exterior brick wall. It is not come off however when i push it, there is some movement but as i said, only a small section. The house is an old house built in 1910 so the exterior walls are not insulated and because of that in winter there is quite a lot of condensation forming on the exterior wall. As i said the bathroom is tiny, so no way i can build a stud wall. Would it be ok to screw a sheet of plasterboard direct onto the exterior wall? Is there a specific plasterboard which helps reducing condensation which is suitable to screw straight onto the wall? Just for your info, the wall will be tiled up to the middle and painted from the middle to the ceiling. Thank you in advance for your help.
