I'm going to put an electric Dimplex towel in my bathroom and would like to to fit a timer so I can make use of economy 7 but still want it installed so I can use it during the day if required. I can't find any on the internet do they exist?
You could use a timer designed for an off-peak Immersion heater. Some of then provide off-peak heating with a manual "top-up" at peak rate. They will switch a 16amp appliance which should be suitable.
Horstmann do such a timer, it is about £60
Be aware that if you have separate circuits for off-peak electricity (like an old "economy 7 installation) then you will have to have two supplies to the timer. Since it is in a bathroom as well (which is notifiable work) look for a suitably qualified professional electrician who is a member of a self-certification scheme.
I do have separate circuits (off-peak and on-peak) but it is my understanding that between midnight and 7am, both circuits are on the cheaper rate (day rate 35p + vat). I only have space for one towel rail which will have to be connected to the on-peak, hence the timer. If I turn in on when I get up, its just staring to get hot when I have finished, and the kids forget to turn it off, so are left on all day.
The work will be done by a part p electrician, but I just need to work out what I want and need and where to put it.
then a simple timer with an override would do it. Again, an Immersion timer would be suitable. You might not need such an expensive one. They do not have their own fuse, so if it is off a ring, you will need a fused flex outlet or something.
