Timer On Ring Circuit
13 Oct 2010
Yorkshire
I want to put a timer on my upstairs ring circuit so all the upstairs sockets turn off at a set time as the kids go to sleep leaving there tv's, computers, playstation etc... on. Can this be done, if so, how?
Many thanks
Yes it can, but it wouldn't be cheap and it wouldn't be easy, as you'd need to find, and find a way to fit, a timer rated at 32A at the origin of the ring in the CU.
Or you could power all of those items from multi-gang socket strips plugged into plug-in timers in sockets.
Bish-bosh, no wiring, job done in a few minutes.
You could use power strips plugged into remote control sockets - and keep the remote.
But it probably won't take them too long to work out how to bypass it.
I need to make it non adjustable so kids can't tamper so plug-in timers are not suitable. Can a lower rated timer be placed on a separate 6A braker and a 50A contactor on the ring with the timer controlling the contactor, or is that not possible?
Why don't you just each your children to DO AS THEY ARE TOLD! It's called discipline and and it's GOOD FOR THEM.
If they don't do as they are told, you punish them - take the computer game away for a week.
Yes, that's possible.
But what if they leave a hairdryer or something switched on, it's turned off at the timer, and then comes on again when the timer resets, but no-one notices, and the house burns down?
Many thanks
Sounds like a dopey idea.
Also sounds like your home has a discipline problem.
I presume electric alarm clocks still have a battery back-up facility.
Do you not have an alarm clock or a phone charger or anything like that that you have plugged in on a night time?
