Hi all,
so i'd prefer to tile to the bottom of the wall and put the skirting on after as it will be neater, plus the skirting is fairly low profile finishing in a pretty fine point at the top and tiling down to the top of it would look daft.
However if i do tile under the skirting then that means i have to tile under the arcs as well, which i don't want to do cos then i'd see the tile edge sandwiched between the door frame and arcs, get my drift?
If i tile up to the arcs then when i put the skirting on it will stand prouder than the arcs if you see what i mean?
Your thoughts please? Any way around this?
