Hi guys
Picture below is the space I am working with. Distance from the edge of the white pipe to the false wall framing is 6 inches. Further to my previous thread last night ("Now I am not happy"), I have cut away part of the tile to gain access to the soil stack and replace the flexible hose which connected the pan to the stack. It had a very small rip in the pipe causing the leak behind the false wall.
Can this 90 degree WC pan connectors be cut to shorten the straight run?
http://www.screwfix.com/prods/15330/Plumbing/Macerators-Connectors/Wc-Pan-Connector-90º-Bend
Can the ribbed rubber seal be removed and the pipe shortened to suit my setup? Can other "connectors" be placed between the collar of the above connector and the actual toilet pan flange.... i.e. I don't think the above would reach the toilet pan. Would need to add something else to then connect to the toilet - is this ok?
I don't want to use a flexible connector if at all possible due to the current problem, but I may not have much choice.
Would really appreciate your comments / help!!
Thank you
Thank you
