The 4inch waste is about 200mm off the wall... I wonder if i use a swan neck multiwic could i fit a close coupled toilet.. plan to remove low level one... can put up picture tomoro if needed
Seen that loads of times. A swan neck will help but youll be very lucky if its enough. You will probably have about 40 or 50mm gap left. A painted baton doesn't look bad to fill that gap
