Torbeck INSTRUCTIONS
7 Dec 2007
I have fitted in haste a new Torbeck as I was faced with a tiny cistern which could not accommodate a Delchem float valve.
The bloke in the merchants said to read instructions but I was confused and could not grasp how to adjust the telescopic arms so I managed to get a reasonable fill height using the float.
I also had a flow restrictor left over.What is the default-I presume the pre-fitted is for high pressure.
I will have to buy another and dismantle to work out to get the best out of it.It seems a big improvement on the trad fittings. Can anyone offer advice on this one?
Is it working ok ?
The float is adjusted by turning it clock or anti clockwise and you should play with it until you get it to cut the flow at the right water level.
No need to buy another ! :confused:
Thanks Bahco it works fine.I have set the float so it fills adequately but I could do with lengthening the vertical arm.I think the merchants must have had people fitting them wrong and has overegged the reading bit.I just feel that I may have missed something crucial.
Quite a good solution for a smaller cistern which cant accept the Delchem ball valve arms as it is too cramped etc.
Best wishes GNVQSOS
