Trevi Boost Exposed
11 Sep 2007
Hi Guys,
Planning to fit Trevi boost exposed valve, instructions state 'must use 22mm from hot supply'
Does anyone know if this is a 'MUST' or are they covering there backs and 15mm will work fine?
Reason is the pipework will be exposed and feed into bottom of shower, and 22mm will look b***** awful, was hoping to run 15mm chrome plated.
Look forward to hearing from you.
if the makers say its a must then its a must
unless you dont care about any guarantee
22mm is a must for the hot on a Trevi boost. RTFB!.
Why not fit concealed valve? Can you feed from behind? Or try a different shower that can have two 15mm feeds...
Hi Leakydave!
Thanks for the reply, this is in a OLD house with very proper wall, the only posible of way of bring in from the rear and concealed would be to chase out a very big bit of the wall, which obviously is a lot of work, retiling etc, not sure I want to go down that route.......
Due to very high mains pressure and hot water being low as fed from tank, I think the Venturi is the only way to get a shower in the house..
Do oyu know a venturi that has 15mm feeds on hot then?
Are you aware how this type of ahower works? If you don't maximise the available hot supply it won't work (very well). A 22mm supply here is not an option it's a must. ;)
Normally the 22mm requirement seems a bit ott, when both H and C are going to have to share a 10mm hose, but I think in this case, on the hot side, it could make a difference.
Being me, I'd try it with 15mm but keep it very short.
Breesey, Yep, know exactly how the venturi principle works.
Aside from understanding this principle, I have a Venturi shower in my house, not sure of the make (its a round horrible looking thing) but this shower is fed by 15mm on the hot and cold, and apart from a all singing all dancing pumped mixer shower its by far and away the best shower I have ever had, temperature control is very good and a pretty powerful shower to boot........
Hence my question 'is there any that have 15mm feeds' I am pretty sure the shower I have is not produced anymore
Run hot and cold in 15, it'll be fine as you well know already. As someone else mentioned it is the manufacturer's gaurantee that suffers here!!
