Triple Pole RCBO?
31 Mar 2006
Leeds
Does anyone know if there is such a beast as a triple pole RCBO?
I am installing some three phase busbar trunking in a factory which will be supplying both fixed and portable equipment. The RCBO would be for a Merlin Gerin Dist. Board and need to be rated at 63A / 30mA type C. If not then I will fit an MCB feeding an RCD in a seperate enclosure, but an RCBO would be the easier and neater option.
i used one in an older style gerin board some years ago so i would expect them to still be available
edited to add
im now sure it was an rcd designed to be fitted next to the triple pole breaker in the board
As ch427 says you can get an RCD as a add-on for a Merlin Gerin 3phase C60HC MCB, this will take up an additional 3 modules adjacent to the MCB in the distribution board, Merlin Gerin P/No MGV 63 030 4 (63A, 4pole, 30mA trip).
