My Triton 2 shower has worked fine for years. However ...
I had to repair the feed cable (due to a mouse) and now the power is restored to the pull switch - the red light goes on when switched on.
But there is no power light on the Triton 2 (so no power from the pull switch)- which should be on constantly when pull switch feed is on.
However if I turn the shower to on, nothing happens to the shower (as there is no power to it) but the red 'on ' light on the pull switch goes off!!
No re-routing off wires has taken place - all I have down is repair the feed cable to the pull switch and then replaced the pull switch - as I thought the mystery must have been caused by a faulty feed switch.
However having replaced the pull switch, the same problem occurs i.e. when the shower is turned on, it turns off the light in the pull switch.
I am totally confused and would be very grateful for any ideas at all as to why and how this is happening.
Many thanks
Many thanks
