This is the 2nd unit I've had now that cycles hot and cold. When it goes cold it usually only stays that way for a second. The 1st unit pretty much burnt out with the live wire melting through and burning the plastic. I sent a picture to triton but they weren't bothered.
Anyway ive read that it could be the thermal cut out valve. Is there anyway to check this?
If it is the pcb obviously ill be getting a new one. The problem is im very limited to space as the shower screen is very close and the water pipe and electric inlet has to be in the same place.
Can anyone recommend another shower (not triton) that would have similar inlets?
Many thanks
Many thanks
