I have a little knowledge of plumbing and central heating systems but i am by no means a plumber. I've recently replaced the old rad valves in our house with TRVs and was told that i should retain the room thermostat but set it to max and then set the TRVs to the required temp. I have done this but on thinking about this further i understand that the TRVs only shut off the radiators they are attached to and will not turn the boiler off (we have a combi boiler)? Or does the boiler recognise that all the rads are shut off and turn itself off?
Should i turn the Room thermostat (which is in the hall) down to a more reasonable temp so it turns the boiler off at some point rather than running constantly and should the TRV on rad in the hall (with the Room Thermostat) be set to maximum?
