Guys,
When did the regs change to specify that a time delayed 100ma RCD main incomer had to be used on TT supplies in conjuntion with a 30ma RCD for the socket circuits.
I only ask as i've just popped up the road to reset the RCD for an elderly neighbour and her consumer unit has obviously been changed recently and the earthing has also been updated. I'm told this was done by an electrician last year but no time delayed RCD has been used. Its just a standard wylex split load board with 100a main switch and 80a 30ma RCD. The lights and cooker are fed from the main switch side with the sockets being on the RCD side, also one Siemens MCB has been used for one of the socket circuits. The overall CU change looks a bit scruffy as well, i mentioned it wasn't to current standards and would probably need to have the main switch changed but i said i'd double check and let her know.
Has the "spark" messed up or was it just not in the regs to use time delayed RCD's until recently?
Dan
Dan
