I have a Creda dryer, drum rotates all seems to work fine but will not heat the air. Does anyone know what could be the problem. I've done a continuity test on the heating elements and that checks out ok.
The stat / overheat stat will blow if you don't let the machine run to the end of a program, the last 10 mins of which is cooling down. If one has gone the other is probably damaged too, so always change them in pairs (they are usually sold in pairs, £10 - £15'ish). Here is one source I have used http://www.appliance-spares.com/
