I need to turn off my hot water to work on a tap in my bathroom but unable to locate a hot water isolation valve. I have what I believe is a high pressure system (the hot water tank a Gledhill stainless lite, is in the loft with a pressure cylinder, no cold water storage, boiler down stairs in the laundry/utility room). I have looked in the loft not able to see anything resembling a hot water valve. Also looked in the airing cupboard, there is a value but this seems to be a cold water feed. I have located the pipe that feeds the hot water into the bathroom and can't see a value any where along the pipe from the hot water tank into the airing cupboard then off into the bathroom. Any suggestions on how to isolate hot water?
