Hi guys,
I'm really getting into this forum now, been chugging on with DIY thanks to you all.
Right..
We currently have an aerial socket in the lounge, which we use for the downstairs lounge TV.
I've ventured up the loft, and the aerial is roof mounted, and comes through the roof down the wall to the lounge.
A you can see the aerial comes through the roof.
Next,
It goes down the wall to the lounge.
My thoughts are,
I cut this cable, and fit a box/splitter type thing with 3 ports(1 for lounge, 1 for bedroom, and 1 for another bedroom should we ever need it).
Then, connect the half of the wire that I cut into the main port on this box/splitter.
Then simply use the lounge wire and connect that up.
Then run another length of wire to the bedroom and the other bedroom.
Then, drill a hole in the corner of the room by coving to feed the wire to the TV.
Or if possible go down the cavity and pop out and fit an aerial socket on the bedroom wall.
If I am way out here, please do let me know.
Any help is truly appreciated.
Right..
Next,
My thoughts are,
