Hi all,
I have recently replaced my TV aerial which snapped from old age with a 48 element wide band TV aerial. I used a LABGEAR DVB signal finder and found the lights will not go past 50 (first LED), which I did not find improved the picture as I originally put the aerial up with out the signal finder! aerial is pointing in same direction as other house aerials. The Mast aerial then goes into a TV booster (in the loft) and then to 4 x separate TV around the house.
The problem I have is that channel 4 has ghosting, on a freeview TV set not all the programs tune in, and some freeze for a second sometimes and then resume to normal. The TV set the furthest away from the booster has a worse picture.
Any help would be appreciated.
