I've got one of these which I'd like to install:
http://www.amazon.co.uk/Micromark-MM18541-Kingston-Luminaire-Chrome/dp/B000EBGKAE
Inside there is a choc-block next to the lamp holder which I would have thought you could just connect the 1.5mm T&E (loops at the switch so only 1 or 2 cables to connect).
Now, looking at another one already installed, whoever did it connected three H05S-U singles to the internal choc-block and then connected these to the T&E with another block left flapping about in the ceiling void.
Wanting to avoid the unenclosed connections, can I just run T&E straight into the light?
Since these lights will only be used with 15-20W CFLs (or 60W incandescent bulbs) , do I really need high-temperature cable/flex?
Thank you!
Thank you!
