I have recently had a look at a plumbing problem in someones house, They have issues with radiators not heating up enough and a problematic shower hot water issue.
I'm not sure if the two problems are linked.
They are currently running a Myson 70/90 oil fired boiler its a largish house with 4 beds 3 bathrooms.
The previous plumber has installed a second cylinder next to the original by linking all the pipe work together they are both situated in the loft (with no pipe insulation).
Apart from anything else is this set up against the regs? and could this extra cylinder be causing problems with the rads not heating up and the shower hot water issues?
Any thoughts anyone..?
