hi we have a dining room which has two electric dimmer switches in it controlling one light the switches are GET electric dimmers which seem to have burnt out
one of the switches has lots of wires going into it the other dimmer just has three wires, one is a plain red the other is a yellow with a red sleeve on it and the other is a blue with a red sleeve (but thats taped up and not currently in the switch.
Im looking to replace the dimmers in the room. I think i will just get one rotary dimmer and a normal on/off switch.
im looking to find the right switch as its a two way switch but need help selecting the right switches
this is the back of the switch where all the wires are going into
the blue wire with red sleeve is into the sqiggly patten
the two plain red wires are going into the L
and the black wire with red sleeve and yellow wire with red sleeve are going into the RS connector.
and then this is the other switch with just the three wires, this one if you hold the switch will on the light will turn on but only while you hold it.
