Type of mortar?
5 Nov 2017
Hi all,
I'm looking at doing some re-pointing to my house but I want to make sure I'm using the correct type of mortar (lime or cement). How can I tell?
I have asked a builder and he assures me it is cement.
The house is a traditional semi built in 1955-1960.
Ok to just use a 4:1 mix of cement and sand?
Thanks' all
looks like sand cement only to me.
However there are different sands, depends on whether all your local merchants buy from the same quarry in your area.
The original looks like building sand, which would normally be used on work like this. Building sand does contain a few larger particles which show through when the laitance from the original jointing weathers back. As a rough guide the largest particles should be no more than 1/3 of the joint size.
The workability of sharp sand can be improved by mixing for a good 30 minutes, or about 20 with lime mortar, but in this case I myself would be using a building sand.
