Well, I have learnt a lot in the last week! First of all thanks to ianmcd for the advice - it kept us warm! There were 2 Wilo pumps at B&Q: One B rated, about 50W and an A rated smart pump 15 - 45 W. The B rated pump head was the same physical size as my old pump, so I bought that one - mistake, when I split it, it was obvious that the design was completely different. Took it back and exchanged for the smart pump, which had a smaller outer diameter, however the fixing hole centres were the same. Split it and noticed that it had a smaller impeller, however I was able to fit it to the old pump body. It worked but not 100% correctly. The boiler was not able to modulate correctly and could not cope with the times of the day when we have only 4 rads on. So, instead of settling down to a steady output, it was hunting around the set-point, overshooting and shutting down, then firing again after the pump time-out period. The house was still warm but I presume at a cost, due to the boiler not operating in the most efficient way. Whilst taking a shower, the temperature would fluctuate. Managed to get hold of a second-hand original pump head off e-bay for £30. Just fitted and it's working fine. The official new replacement is a Grudfoss but you have to change the complete pump, as the head will not fit the old body - £119 + VAT from my local stockist but there were none in stock.
