hello all.
I am planning to install under cabinet lighting in my kitchen. Just need some clarification on the setup.
I plan on taking the power supply from a socket to a fused spur switch using 2.5mm cable and then connect to the lighting using 1.5mm. Is this standard? Just a question on the fused spur.. I have read on forums to use a fused spur with a 3amp fuse. Can you get a 3amp fused spur? Or is it a case of getting a 13amp one and changing the fuse?
thanks!
thanks!
