I am planning installing a underfloor (wet) heating sytem in the conservatory ive just built and wondered if i need an extra pump to give the added boost.
The existing boiler is a Wicks Ace high 102 btu which has been running fine for a number of years and runs 7 radiators (3 large and 4 small).
Im presuming if i do need a pump that it will have to connected to the boiler pump, to come on as the boiler pump activates.
Im planning having a seperate switch inside the conservatory to turn the heating on as needed so presumably ill need a zone valve to disconnect the underfloor heating from the existing heating when not in use.
Any advice appreciated.
