In order to ensure through air flow from the front of the house to the back the guy drawing the plans for a ground floor side return extension has suggested excavating a 700mm void under the entire new floor area, laying a concrete base with joists running above the void. The builders have suggested a solid screed onto the ground with ventiation pipes running through. The latter is a lot cheaper as does not involve excavating the entire floor area.
Thoughts on why either may be more appropriate would be appreciated.
