I've recently had a problem with the gutter drainage into the ground drain. The driveway around the drain had begun to sink, and upon digging around it I discovered that the cement around the p trap to the underground pipe had broken away, and to add to that, the underground pipe was blocked (and yes, it's a clay pipe).
I removed the p trap and unblocked the pipe, but upon putting the p trap back in place, the collar on the underground pip broke off.
In a nutshell, I just want to know the best way to reconnect the p trap to the underground pipe without having to replace the underground pipe. The underground pipe's internal diameter is 82mm, so I'm wondering whether there's anything around that I could use to step down from the existing p trap (external 110mm diameter).
I've looked everywhere I can think of and can't find anything suitable.
