Hi guys.
This has confused me so hopefully someone can explain.
This is a typical 3 bed terraced, 2 living rooms.
The tennant has moved out this week so some superficial renovations are being done.
I knew we had a damp issue in the back room which I assumed would be the open chimney (at the top) and vented at the bottom. But when we had a closer look we saw some other issues.
All of the internal wall with next door is showing signs of moisture, it only raises a couple of foot but has effectd the skirting boards etc.
The two living rooms effected have concrete floors fitted.
Knowing I had some issues I had always looked up and thought that the chimeny/flashing would be the issue but now I am not so sure.
Can you get rising damp on internal walls ?
Could this just be an age thing for the house. It is 100 years old and the skirting boards and plaster wallas are at least 20 years untouched.
