Hi I have an extra wired ceiling rose in the bedroom I want to remove. There is a main light in the room which is part of the same circuit that I want to keep. I bought a maintenance free junction box to terminate the cables in and push up into the ceiling void and fill the hole. The hole for the extra ceiling rose is only small, much smaller than the Ashley junction box I have got to use. So i'll have to make the how bigger to fit the junction box into the ceiling, which seems mad because the end result is to fill the hole in.
I was wondering if it was possible to use Wago connectors at the end of each wire and just push them through the hole into the ceiling because they will fit through the original hole and not use the junction box at all?
Or is the best way to make the hole bigger and use a junction box?
Cheers
Cheers
