HI, I have a friend who has what I think is an unusual plumbing arrangement for her DHW. The feed to and supply from the DHW cylinder are as normal. However there is no immersion heater fitted and instead the boss has been blanked off and has two 15mm pipes coming out of it. I imagine thes pipes are linked together inside the cylinder to provide a heating loop. One pipe is connected to the CH supply and has an open ballofix valve fitted. The other pipe is connected to the CH return and both of these pipes are interconnected with a closed ballofix on this connection. The top boss for the heating coil (don't know if there is a coil fitted or not) has been blanked off. The cable to the pump and boiler a grey twin core and earth. The programmer allows for control of the CH only. I would really appreciate you comments on this arrangement. Many thanks
