- Joined
- 26 Oct 2020
- Messages
- 24
- Reaction score
- 3
- Country
Hello all,
I’ve been pointed to this forum as a source for help in a question over heating / hot water systems. Apologies for the long winded post to follow!
My 4 bedroom, 2 bathroom house was built on 1999 and is currently heated by a Potterton Supreme heat only boiler and a gravity fed hot water cylinder.
In December, we will be having both bathrooms refitted (no real issues, other than they are tired), and wanted to try to improve the shower performance at the same time.
Herein lies the problem. We are getting conflicting advice between the various people who have quoted for the above work, and wanted some independent/ real world advice.
I cannot measure water pressure, but the property (on a housing estate) gets around 12-15 ltrs/min, depending on the time of day and tap.
While the property is fed by a large diameter water inlet (32mm), this reduces to a 15mm pipe at the stopcock.
Interestingly, the Mira Thermostatic Mixer shower in the en-suite (which is the main reason for the question), outputs around 7 ltrs/min, with the dial set to cold only and shower head removed, where as the bath tap outputs over 15ltrs / min.
We have been offered three options to improve the shower performance:
1) Unvented Cylinder.
Question : Most systems (Megaflo and RM) seem to suggest a minimum flow of 20 ltrs/ min, but some plumbers are still suggesting this. Will it work and give us a good balance of pressure / time of hot water?
2) Combi Boiler
At some point, I know the boiler needs to be replaced. One installer has suggested just installing a large (36KW) Combi, which will provide a cost effective solution and offer improved water performance. I recognise I lose the backup to a hot water tank, but I also understood that Combis are not recommended for larger (18 radiator) houses?
Question : Is this worth considering and will it have any effect on shower performance (other than having unlimited hot water)?
3) Digital Showers
Only one installer has suggested leaving the heating system alone and buying two digital shower pumps, located in the loft space (to reduce sound issue) and plumbed to the current hot water tank.
Question: I would guess our current cylinder is around 200ltrs, meaning that, even with a mix of cold water, showering time would be limited at a flow rate of 20+ltrs / min. Is this a viable option?
Apologies again for the long post, but does anyone have any thoughts / experience on the above and can offer some advice?
Thanks again!
2) Combi Boiler
3) Digital Showers
Thanks again!
