Hi There,
Hope someone can help with this problem as my house is getting pretty cold!
I've changed a radiator on Saturday and once the new one was connected I can't get the CH system to work.
I changed the radiator by closing the valves at the bottom, draining and then installing the new one. But when putting the CH back on the boiler just cuts out.
I've had this problem a lot in the past and it's been due to airlocks in the system which are extremely difficult to get out. Both times I've had work done it's taken the plumber half a day to get the system going again.
I bleed all the radiators from the bottom of the house then up to the top and bleed the valve next to the CH tank but my boiler still wouldn't start.
The only option that's worked for the plumbers in the past is to drain the system and then refill. I tried this but now I can't get any water in to the radiators upstairs.
The downstairs ones filled up but very very slowly but 24 hours later and there's still no water in the radiators upstairs just air when I bleed them.
I don't know whether this is due to an airlock again or whether I've got a blocked cold feed which I've seen on this site can be the cause of this problem.
Problem is being no expert I'm not sure how to determine what the cause might be.
Any help is greatly appreciated!!
Thanks.
Thanks.
