my upvc door when closed on lock side at top, shows a gap at on lock side.
on hinge side looks ok
when door is in the locked positions door is tight against frame, down both side of hinges and lock side and on the bottom, at the top of the door frame is against frame on hinge side but slopes down towards lock side which does not cover seal, hinges do not have adjustment for moving door upwards, is this a case of toe and heal , or do i need to adjust door some other way, type of door is a reinforced panel in bottom have and 2 sealed units in top half
any help with problem would be appreciated
