Hi its cold up here in Scotland so your help would be gratefully appreciated.
My baxi 105e developed a problem on christmas day with a ch failure although the hw is fine, had been having an intermittent fault with timer
so suspected that first, no apparent fault ? (but shall be replaced) As control box was dismantled checked out pcb and components. Found resistor r23 to be blown and cannot source this 250k resistor locally until well into the new year. This effectively means that the ch is switched off.
Question is before I fork out over £100 for a pcb and timer can anyone suggest other than a fault with the timer why this resistor should fail?
as I dont want to fit a pcb only for it to fail instantly.
merry christmas and a happy new year to you all.
