"We recall some examples of BTVision shipping older Comtrend adapters several years ago, which made some people unhappy. In a few cases similar kit was also blamed for causing interference with sound systems, DAB/FM radio and even broadband ADSL lines, among other things."
https://www.ispreview.co.uk/index.p...te-owners-bad-powerline-network-adapters.html
I dunno, but this does not sound reason the ban them...
My neighbour's tree interferes with my satellite signal. Maybe we should ban trees.
I've still not heard a case when a radio signal was blocked by such a device. Crackle and pop maybe, but not actual blocking.
My mum's food mixer used to interfere with the radio. I might have to report her and her food mixer to the radio police!
Can we have some real life examples, rather than just theoretical problems?
, and when people used proper antenna there was no problem.
These unrecorded cases of voluntarily taking equipment out of service, is this just some very isolated cases, where Mr X complained about his neighbour's internet and somebody asked him politely to switch it off.
I think being asked to switch would be a bit more forceful than you suggest
if it turns out to be next doors vacuum cleaner, they will be told to get it fixed, it is the same with these LAN extenders,
if you sat under cables and transmitted the signal would follow the cables making it hard to find the fox, same with these units, you may know what is causing the interference but it is radiated from power cables so very hard to pin point.
AIUI, one of the tricks is that these units are tested while plugged into a filtered socket - and lo, they pass the required EMC tests to be legally put on the marketI would guess although never tried one can plug one of these LAN extenders into a filtered socket and the interference will be within the EMC limits, although likely it would not work, but the unit passes the tests until you plug it into an unfiltered socket ...
