- Joined
- 17 Aug 2005
- Messages
- 13
- Reaction score
- 0
- Country
Ive temporarily (whilst the ceiling is still down) wired 6 halogen spots in parallel from a central junction box with 1.5mm t&e. To make the final wiring easier Ive thought about using 1.5mm flex instead, as its easier to fix into the spot "housings/connectors". Is there any reason why this shouldnt be done?
Also how should the earths be connected at each spot? as they only have 2 connectors (obvioiusly l & n) Should a connection to earth be made for the metal back section of the fitting for instance?
Thanks in advance for the advice.
