Needed to change the diaphragm in the water section of the above boiler so whilst the system was drained decided to change the diaphragm in the differential valve at the same time. Big mistake (if its not broke don't fix it). Now the boiler won't flash up, the new diaphragm is not pushing the pin out with sufficient force to operate the gas valve!!! Stripped everything down and checked all was clear ie the two tubes and also cleaned the venturi. Couldn't find anyting wrong but still no joy. Any suggestions? By the way I had a spare (old) pump which I've put in but still no go
