Vaillant boiler code S7
15 Jan 2017
free flow system vaillant boiler is displaying a code meaning pump over run could anyone tell me how to fix it plz
Tank in the loft boiler downstairs not a combi
Hi I've got a free flow system the heating won't come on and the boiler attempts to fire up it says code s. 7 anyone know how I can fix this please
Yes it fires up and starts rising cuts out at around 70
It's a free flow system with a vaillant ecotec plus boiler (condenser) it displays an error code s. 7 which means pump over run
Yeah gravity fed not a combi the tank is in the loft, don't know what s plan or y plan means
you have an open vented system not a free flow as you call it and s codes are not fault codes they are simply telling you what the boiler is doing
S7 just means the pump is still running for a few extra minutes after the boiler has finished firing to carry off the heat from the boiler.
Does it get to 70 in a very short time and what sort of motorised valves are in the system?
Some of these
or one of these
That's all it says it tries to heat up and cuts out at 70-80 in a short time the valve still works
