Vaillant Combination Boiler
My boiler has developed a water leak and after removing the cover I have located the drip coming from a joint, which can be seen in the photos.
Its not a compression joint and there are no signs of it being soldered so can anyone shed any light as to weather its something I can fix myself?
I can’t see how the copper pipe is fitted into the joint unless it’s a tight push-in fit with a rubber grommet.
